Maximize Your CNC Uptime with DATRON Service
In the manufacturing industry, unexpected downtime of a CNC machine often brings production to a halt. This can be both frustrating and costly for business owners. When a DATRON machine experiences issues—whether it has stopped functioning, is producing unusual noises, or is displaying incorrect language settings on the controller—the DATRON Service Team is the go-to resource. This blog aims to explain how the Service Team works to get machines back in operation quickly, helping to maximize CNC uptime.
The Most Important Number to Maximize Your Uptime
The single most important resource for DATRON machine owners is the Service Hotline. This is a lifeline when technical challenges arise. Unlike generic support systems that route through multiple layers, the DATRON Service Hotline connects machine owners directly with the support team. For convenience, be sure to keep this number readily available: 603-215-5870.
The DATRON service and applications team is dedicated to your success and communicating best practices for high efficiency.
When calling the Service Hotline, you are connected directly to the Service Department. The first point of contact will ask whether the issue is related to Service or Applications.
  • Applications-related issues (such as questions about speeds and feeds, tooling recommendations, or machining strategies) are directed to the Applications Department, where specialists can provide guidance.
  • Service-related issues require a brief description of the problem, along with the name of the company calling. This information allows the team to quickly review account details and machine specifications. From there, the caller is transferred to the next available technician for further support.
Help Us to Help You to Maximize CNC Uptime
Once connected with a Service Technician, a case will be created to document the issue and track progress toward resolution. During this process, a few initial questions will be asked to better understand the situation. Having this information prepared in advance helps streamline the diagnosis and ensures faster support, ultimately minimizing downtime.
Understanding the ABC File
One of the first items a technician may request is an ABC file. This diagnostic file provides a snapshot of machine activity, allowing the team to see critical details such as whether the system was improperly shut down or if there was a crash on one of the axes. Supplying this file gives technicians valuable insight into the root cause of the problem.
Below are the steps to retrieve an ABC file from a DATRON machine:
Generate ABC Report
  1. Navigate to the main screen of the DATRON software.
  2. Press “S” for Service.
  3. Press “R” for Report.
  4. Press “R” again, or “E” for Extended Report (depending on your software version).
  5. A screen will appear allowing you to select the path to your USB drive and save the ABC report.
Once the file is saved, transfer it from the USB drive to your computer and email it to [email protected]. This ensures the Service Team has access to the diagnostic data needed for troubleshooting. For the fastest support, it is recommended to send this file in advance of calling the hotline, when possible.
Generate Diagnosis File on DATRON neo
Note: Owners of DATRON neo machines will not be able to generate an ABC file. The neo uses a different type of diagnostic file and software. To create this file, follow the quick steps outlined below:
  1. Navigate to the main screen of the next software.
  2. Select Settings.
  3. Choose Utilities.
  4. Select Diagnosis File.
  5. Click Create Diagnosis File.
  6. Once created, select Copy to USB Stick in the bottom-right corner of the screen.
The diagnostic file is now saved to your USB drive and can be transferred to a computer for emailing to [email protected].
Parts and Service Support
After a technician has reviewed the diagnostic file and identified the issue, it may be determined that replacement parts are required to restore your machine to full operation. In such cases, the Service Team will provide a detailed quote, confirm shipping timelines, and ensure that the necessary parts are processed and dispatched as quickly as possible.
At DATRON, the top priority of the Service Department is to minimize downtime, keep your machine running at peak performance, and ensure that your business operations continue without interruption. The dedicated Service Technicians will support you through every step of the process.
