Skip Secondary Finishing. Ship Parts Off the Machine.
In aerospace manufacturing, machining is rarely the final step.
After the part comes off the machine, it often goes somewhere else.
Deburring. Polishing. Hand finishing.
Steps that add time, cost, and variability.
Steps that don’t create new value, only correcting what the machining process couldn’t achieve.
The Hidden Drag of Secondary Operations
Secondary finishing is so common that it’s often accepted without question.
But it comes with real consequences:
- Additional labor requirements
- Increased handling and risk of damage
- Longer lead times
- Inconsistent results
Each time a part leaves the machine, the process slows down.
And every additional step introduces variability.
In aerospace, where precision and repeatability are critical, that variability matters.
Why Secondary Finishing Exists
Secondary operations are usually a symptom not a requirement.
They exist because the machining process didn’t fully achieve the desired result.
Common causes include:
- Chatter from unstable cutting conditions and excess vibration
- Burr formation during machining
- Inconsistent surface finishes across features
To compensate, shops add finishing steps. Whether its tumbling, deburring or polishing its additional work that slows down production and shifts resources to rework and cleanup.
Not because they want to, but because they must.
The Cost of “Good Enough” Machining
Many machining processes are optimized for reliability, not perfection.
Conservative parameters reduce risk but come at the expense of cycle time and throughput.
The result:
Parts come off the machine “good enough” to finish later.
But that mindset creates a hidden inefficiency.
Instead of solving the problem at the source, the process pushes it downstream.
And downstream work is always more expensive, more specialized and not as repeatable.
Surface Finish as a Production Strategy
What if finishing wasn’t a separate step?
What if the part came off the machine complete?
This requires a shift in thinking.
Surface finish is no longer just a quality metric.
It becomes a production strategy.
Because achieving the final surface in-cycle eliminates entire steps:
- No secondary handling
- No additional labor
- No waiting between operations
Just finished parts ready to ship.
What Enables Better Finishes In-Cycle
Achieving high-quality finishes directly off the machine isn’t about a single variable.
It’s the result of a stable, optimized system:
High Spindle Speeds
Allowing for cleaner cuts, reduced tool pressure and better finishes.
Stable Cutting Conditions
Minimizing vibration and chatter that degrade surface quality.
Optimized Toolpaths
Reducing tool marks and improving consistency across features.
Consistent Workholding
Ensuring the part remains stable without deformation.
When these elements come together, surface finish finishes naturally without slowing down the process and often lower cycle times. You’re able to achieve better surface finishes faster.
The Throughput Advantage
Eliminating secondary finishing doesn’t just improve quality.
It transforms throughput.
- Parts move directly from machining to inspection and assembly
- Lead times shrink
- Labor requirements decrease
- Production flow becomes smoother
Instead of batching parts for finishing, shops can move continuously.
Less waiting. More flow.
Reducing Variability
Manual finishing introduces inconsistency.
Even skilled operators produce slight variations.
In aerospace, those variations can matter.
By achieving the final surface in-cycle, the process becomes more controlled.
More repeatable and ultimately more scalable.
A Better Use of Skilled Labor
Skilled machinists and operators are valuable.
But their time is often consumed by non-cutting tasks:
- Deburring edges
- Polishing surfaces
- Correcting minor imperfections
When finishing is eliminated, that time is redirected.
Toward higher-value work:
- Programming
- Process optimization
- Increasing output
The result is not fewer people.
It’s more output from the same team.
The Shift from Correction to Control
Secondary finishing is, at its core, corrective.
It fixes what the process didn’t get right the first time.
Modern aerospace manufacturing is shifting toward control instead.
Designing processes that produce the correct result from the start.
No correction required.
The Real Opportunity
Most shops focus on reducing machining cycle times.
But machining cycle time is only part of total production time.
When you include:
- Setup
- Handling
- Secondary operations
The true opportunity becomes clear.
A New Standard for Aerospace Manufacturing
The expectation is changing.
It’s no longer enough to machine a part accurately.
The goal is to produce a finished component directly off the machine.
No extra steps.
No added complexity.
Just clean, consistent results.
Looking Ahead
In the next article, we’ll explore how reducing operator dependency is becoming a critical advantage in aerospace manufacturing and how modern systems are enabling teams to produce more consistently.
Because the future of aerospace production isn’t just faster machines.
It’s smarter, simpler processes.
Machining Made Smarter.
Discover how DATRON's advanced machining solutions can help manufacturers rethink their processes, improve efficiency, and prepare for what's next.
Explore DATRON Machines
